avatar_GTX
Alternative Armour Thoughts
Started by GTX, March 10, 2006, 01:48:33 PM
^ Jaaaa, right:rolleyes:  ;D
We do use "Rumpf" for aircraft fuselages and ship hulls (as well as the human trunk/torso), but a tank hull is a "Wanne" ("Wanne" is also the word used for a tub). "Rumpf" can also be used for tanks, but is less common.
Quote from: joncarrfarrelly on May 04, 2011, 10:38:00 AM
Quote from: rickshaw on May 04, 2011, 05:08:55 AM
  It wasn't until well after WWII that you see rear doors/ramps appear for exits.
Tell it to the Marines.
The LVT(3) and LVT(4) had a rear ramp.  ;)
However they weren't intended to be used as APCs originally.  They were "Amphibious tractors."  The naughty Marines decided otherwise.   The ramps were for offloading cargo.   Interesting that their first purpose built APC had a bow ramp.
The US Army didn't use a rear entry/exit on a full tracked APC until the M44/M75.  The British didn't get one until much later.
dy031101
#122
25TP
Length: 7300mm
Height: 2600mm
Width: 2000mm
Weight: 23-25t
Crew: 6
Main Gun: 1 x 75mm
Engine: 2 x 500hp
Projected Performance:
-   On Road 45km/h
-   Off Road 25km/h
To-do list here
dy031101
#124
Have not  :banghead:
(Banging head for being behind schedule)
Another Christie-drive tank (10TP/14TP)...... nice what-if fodder.
To-do list here
dy031101
#125
I failed to notice that a T-28 was actually test-fitted with torsion bar suspension of the KV tank......
Incomplete "Artist Impression" (author unknown).  The tank looks super-cool from this angle.
Curiosity:
1. what was the first good suspension available to the Soviets after the T-28 enters production?
2. are the secondary turret gunners operating the turrets standing or seated?
To-do list here
Quote from: dy031101 on October 21, 2011, 03:59:24 PM
Curiosity:
Define "good".   The Christie was excellent, for what it was intended to do as was the later torsion bar of the KV/JS series.
IIRC they sit, on suspended seats rather like a bike saddle.
Arc3371
apophenia
A view of the T-28's starboard machinegunner's position (and seat)
http://www.saunalahti.fi/ejuhola/7.62/t28_11.jpg
dy031101
#129
Thanks for the pics.  :thumbsup:
Quote from: rickshaw on October 22, 2011, 02:09:24 AM
I was wondering which one of the two came first, but would the Christie suspension represent an improvement over the T-28's plunger spring system despite being meant for "cruiser tanks" rather than "infantry tanks" (which I am under the impression that the T-28 is closer to)?
I wonder how powerful that 95mm gun is.
Wikipedia claims that a later version of the T-29 (recall that it is the T-28 re-equipped with BT-type Christie suspension) was considered in competition against the T-34.  I wonder if its design had undergone any kind of evolution by then.
To-do list here
Quote from: dy031101 on October 22, 2011, 07:00:29 PM
Christie's suspension predates the T28 IIRC.  However, adding Christie to an existing design is no mean feat because of the need to contain the springs in the sidewalls of the hull.  Nor is it necessarily suitable (or cheap!) for a medium "I" tank.  The "plunger" suspension was rather "hard", AIUI.  You could and they did try to put Christie on the T28 but not terribly successfully.   A torsion or even a leaf-spring would have worked well, as would have a Vickers "slow-mo".  All were contemporaneous with the T28.
dy031101
#131
Quote from: rickshaw on October 22, 2011, 08:04:50 PM
Curiosity upon seeing the Panzer 38(t): would there be advantages of leaf-spring system with large road wheels over one with small roadwheels?
(Spin-off: playing World of Tanks last night gave me a bit of inspirations on steam tank ideas after having my T-28 working with a M6 Heavy...... not under the impression that leaf spring is known for high speeds, I still wonder if the suspension can be tweaked into having good speed potential)
To-do list here
Mr.Creak
Quote from: dy031101 on October 22, 2011, 07:00:29 PMI wonder how powerful that 95mm gun is.
Pretty good apparently.
Found this:
95mm F-39, based on 95mm F-28 experimental field gun. L/45 barrel, 13kg@630m/s HE or 11kg@750m/s AP.
Compares well with the German 88 L/56 (810 m/ sec 10.2 kg)
What if... I had a brain?
Quote from: dy031101 on October 22, 2011, 08:25:59 PM
The main advantage of leaf spring systems was that they were (a) technically easy; (b) cheap and (c) worked. Large wheels offer lower rolling resistance than small wheels.  The problem is that leaf springs are easily damaged in combat and so are larger wheels.
dy031101
#134
Quote from: Mr.Creak on October 22, 2011, 09:04:40 PM
Found this:
What's T-28's turret ring size?
Just wonder if the T-34 could have taken the gun.
Quote from: rickshaw on October 23, 2011, 12:32:39 AM
Continuing from the spin-off, can these advantages be equally applicable to countries other than Soviet Union?
As for leaf spring being easily damaged in combat...... would the problem be worse than, say, other systems like VVSS/HVSS?
To-do list here
