avatar_John Howling Mouse
Everything you always wanted to ask...
Started by John Howling Mouse, March 29, 2006, 05:40:48 PM
On WWII a/c, do cannon-armed (as opposed to machine gunned) fighters with wing-mounted guns always have ejector ports for the spent brass casings in the lower wing?
And with propeller-spinner mounted cannon, where do the spent shells go?
I know weight is always an issue but did any WWII a/c have any kind of inner wing collection pot to retain empty brass casings?  I know they'd be pretty hot when first ejected but most metals were quite valuable during the war.
Ollie
On fighters with nose-mounted cannons, no one ever knew what really happened to the ejected brass...
:unsure:
gooberliberation
What the heck is that propellor doohickey on the Me 163's nose? I'm thinking its a RAT of some sort but I havent found any sources saying so.
That's an excellent question Mr Howling Mouse. I suspect all spent brass was ejected. Unless the typical ammo load was only a few rounds, there wouldn't be room to keep all those empty casings.
Gooberliberation,
QuoteWhat the heck is that propellor doohickey on the Me 163's nose? I'm thinking its a RAT of some sort
Close enough - it is a propellor driven electrical generator.
noxioux
A more important question:  Where did the relief tube exit?
Radish
On the '163, the pilot wouldn't need a relief tube 'cause:
a. the aircraft only flew for a short period
b. the damn thing probably blew up anyway
c. or there was a fuel leak which'd melt the pilot before the explosion
d. the pilot was so scared he'd sweat any liquid from his body within seconds anyway
Otherwise, like on the Mustang, it exited down below somewhere.
But a pilot trying to pee, while looking out for the enemy, keeping formation, at 25,000 feet and wearing full flight gear was an extremely manoeverable guy!
I remember reading about a PR Spit pilot who was taken short during a flight. At high altitude, the other problem was a frozen "pee" tube. This happened, pee sprayed everywhere in his cockpit, lining his canopy and freezing. He had to chip frozen urine off the inside of his canopy to see out, wandering all over the place, anxious that a Luftwaffe fighter might spot him. When eventually he regained safer skies and dropped his altitude, his urine-lined cockpit melted of course....he never did explain it to his ground crew!
QuoteUnless the typical ammo load was only a few rounds, there wouldn't be room to keep all those empty casings.
The casings wouldn't take up more room than the unused ammo. IIRC on the A-10, the casings are fed back into the drum.
Spellbinder99
Interestingly, on the Jaguar, the shells from the Aden cannon are ejected but the links between the rounds are retained in two compartments between the cannon.
Cheers
Tony
Radish
And did you know that when replacing certain panels on a RAF Phantom...well, all Phantoms really, the panel came from the manufacturer, then had to be cut to fit, and the necessary holes drilled to match the particular aircraft as they were all different....that's 5000+ all different. :(
RP1
I've been told that the limiting factor for the gun magazine capacity on EE Lightnings was actually the size of the bag used to collect the spent cases!
RP1
"Just your standard-issue big gun."
- Batou, Ghost in the Shell
RP1 dot net
My Facebook
Wow spent casings fed BACK into the ammo drum?! Incredible! I learn something with every visit here. Thanks for setting me straight, gents.
Of course, the info on the relief tube was probably more than I needed to know...
proditor
On the JSF, can you do a rolling short take-off by using the lift jets and kicking the tail nozzle at an angle?  Or does JSF just not "do" rolling take-offs?
QuoteThe casings wouldn't take up more room than the unused ammo. IIRC on the A-10, the casings are fed back into the drum.
Not just the A-10, its common to US aircraft gatlings.
The book "Rapid Fire" is an excellent treatise on the subject of heavy automatic weapons.
As to the JSF and rolling takeoffs, we'll have to wait and see if they develop such a protocol once they have some of the STOVL variant built...most likely its their intent.
Cheers, Jon
waynos
The F-35 JSF cannot do this type of take off, nor does it have any form of TVC like the F-22, It can only point its nozzle straight down for vertical landings, thats it. Of course the F-35 A and C cannot even do this, the jet nozzle on those is firmly fixed. Regarding vertical take offs, this is only possible at minimal fuel loads and with no weapons carried, so basically never then.
The X-35B has demonstrated VTO but of course this is much lighter than the F-35 and carried no weapons either.
It could perform STO by utilising the lift fan but the main nozzle would not move.
