avatar_John Howling Mouse
Everything you always wanted to ask...
Started by John Howling Mouse, March 29, 2006, 05:40:48 PM
All three are the same to me, Leigh, or as they say, "close enough for Gov't work".
QuoteIs R.A.F. WWII "Sky" the same as "Sky type S" the same as "Duck egg blue"?
Sometimes.
gooberliberation
I love this thread.
If I were to do a bare metal FW 190D, would I be correct in assuming that the airframe is all aluminum except for the fabric control surfaces and wooden prop?
It's for a good cause(luft-blasphemy :P )
seavixen
#198
We know of Hercules but was there ever anybody in mythology called Testacles?
If so, I want to build a transport aircraft with such a name. If I have the balls to do it, I may even build a pair!
Might be a hairy experience though!
:lol:  :lol:  :lol:
Stackridge: Rhubarb Thrashers of the World Unite
gooberliberation
QuoteWe know of Hercules but was there ever anybody in mythology called Testacles?
:lol:  :lol:  :lol:
Nobody in mythology, however Testacles was a Greek mercenary who sacked Rome. :ar:
I'll get me coat.
seavixen
#200
Mmm, the words testacles and sack used in the same vein. It must be true then!!  :lol:
Can I say testicles here by the way?  :P
Nick
With all these projects for nuclear powered aircraft, can anyone explain how they would have worked in practice?
I know that nuclear power plants are pretty much giant kettles which make water so hot its steam turns a large turbine etc. but how was that to be applied to a B-52 size bomber?
Nick B)
Hatchet
QuoteWith all these projects for nuclear powered aircraft, can anyone explain how they would have worked in practice?
Nick B)
Suck in air
Heat up air
Blow out air
Basically the same as a normal jet engine, but the 'heat up air' part is achieved with a reactor, not JP. Somewhat simplified of course.
Shasper
Has anyone actually seen a homosexual animal? Scientist say that about 4-5% of animals are gay (IIR the stats correctly), but I'm not buying it.
Shas B)
- Bud S.
Why did the RAF change the desert scheme underside colour from azure blue to black?? Never been able to figure that one out.
QuoteCan I say testicles here by the way?  :P
Yes, but you can't say the thing I'm not allowed to say
QuoteHas anyone actually seen a homosexual animal? Scientist say that about 4-5% of animals are gay (IIR the stats correctly), but I'm not buying it.
There was an incident a year or two ago that caused a bit of a stir.  It was a male duck in Germany (forget the breed) which chased down, killed and then had sex with another male duck, all in front of a zoo-ologists (sp?) office window.  So you had murder, gay rape and necrophilia all in one go.  One in the eye for the "lets all copy the animal kingdom" brigade
QuoteWhy did the RAF change the desert scheme underside colour from azure blue to black?? Never been able to figure that one out
IIRC the black is actually a thick, rubbery coating intended to protect the underside from abrasion from the sand.
Nick B)
Well the German's designed (don't know if it was built) a steam turbine which would have burnt Lignite (plentiful in Germany) which would have then turned the props - so you could have a nuclear powered prop job as well
Shas B)
There was a recent case invoving a Swan in the UK as well. Also of course some fish change sex when there is a shortage of one or the other - preaty rough short straw to pull I would have thought  :blink:
Radish
Meanwhile Sky was a different mix POSTwar to wartime.
The wartime shade was slightly greener; postwar it was more yellowy.
Tamiya Sky is good for wartime usage.
Archibald
Nick B)
As it was said before, the nuclear reactor heat the air. But there's no combustion AFAIK just pump the air, heat it, and reject it. You have a hot exhaust gas plume to propel the plane...
There's two variants of the cycle, the direct cycle and the indirect cycle.
In the first, the hot (and radioactive!!!!!) air is directly rejected in the air... have you ever seen the 3-eye fish in the Simpsons ?  :lol:
In the other cycle there's a radiator, the radioactive air is not directly rejected.
Aparently the Soviet counterpart of the NB-36H was a modified Tu-95 named the Tu-119. all the poor crew has died rapidly of cancer aparently
The Pluto nuclear cruise missile was the most terrifying weapon ever. A flying nightmare...  :angry:
Just imagine a cruise missile (with a nuclear warhead of course) flying at 4000 kph at tree tops, leaving behind its path a highly radioactive contrail...  :blink:
