avatar_Archibald
English electric P.8
Started by Archibald, April 09, 2006, 04:21:45 AM
Archibald
Archibald
My RAF madness continue : this afternoon I made a SR.177...
Archibald,
Quotethe VG would be much difficult to make!!!! Do you have any idea of how putting a VG wing system in a Lightning kit ?
I am actually in the process of planning one of these now - in 1/48 scale none-the-less!.  Might be a while before I am able to post pics though.
By the way, what did you use for the backseat canopy on the P.8?
P.S.  Nice model.
Archibald
The backseat canopy... let's talk about it! it was a real nightmare!!!
It's a very complicated story (I have to made the canopy three times!)
At the beginning, I had used plastic from the bags you can find around the graps of a model.
I had stayed with the dorsal spine of the Lightning, but looking in the book of Buttler, I saw that this spine was deleted on the P.8.
so, taking my cutter, I scrapped it, leaving a long hole... and the rear canopy couldn't stand that and collapsed. the plastic was too supple...
so I found a half drop tank and glued it to the P.8. Then I took the same plastic as before,made a second canopy but the result was the same : bad after paint. So I scrapped it for the second time, leaving the scotch tape.
I needed stronger plastic...
To make my models I use Loctite Super Glue 3. When you buy it, there's a cardboard/plastic package around it.
this plastic is perfect to make canopy : it is strong,supple, and clear.  I was lucky, because there was a small space between the drop tank and the scotch tape left by the second canopy; I delicately slided the new plastic under the scoth-tape left.
But I have to glue it to the forward canopy with a small strip of paper.
If you look at the first photos on the thread you will see that the forward canopy had change a bit.
well now the situation is under control...
Archibald
the BACKSEAT canopy had change, not the forward (:( )
QuoteMy RAF madness continue : this afternoon I made a SR.177...
Interesting! Do you have some photos?
Archibald
Worst, the first two canopies were muddy because of the vapor of the glue. The definite canopy is cleaner (and stronger, but need regular survey because it tend to raise the scotch-tape I used)
Archibald
I have painted it this morning. blue on top, white underside... it had the firstreak of my former lightning (now P.8)
Photos to come soon...
Archibald
Archibald
Archibald
Archibald
Forgot the photo :dum:  :dum: !
Archibald
My P.8 is finished... here's the photos!!
Archibald
