avatar_Archibald
Concorde bomber
Started by Archibald, April 18, 2006, 06:29:50 AM
seavixen
QuoteThere's a white RAF Bomber-Concorde 1/144 on the site of our friend JCC: see http://kitbox.free.fr/reportages/IPMSUK04_...4_P/page13.html
(and in French for you Archie!) :)
Will you be more original including coloured camouflage or something? :D
Crikey, have you seen the Rotodyne on that link? The tiger paintwork is amazing!
Stackridge: Rhubarb Thrashers of the World Unite
Archibald
Wow shasper this is fantastic! Mine will have a bomb bay, a fixed nose and a grey/green camo with French markings. I managed to cut a rectangular hole under the belly, and change this into a bomb bay...
Archibald
Other picture of the future bomb bay...
Quotethe fully loaded twin concorde range : nearly 14000km, as good as an A340!!
How'd make the calculation? A double plane has not double range, if there is twice the drag, twice more engines to feed, there is a little improvement maybe, but only engineers could calculate... well, no: what if the range was 7,000²=49,000,000km=30,000,000 miles, not bad... :D
Quotea concorde bomber. The project was apparetly studied in real world, and I really want to know more about it...
I have just received Tony Buttler's book "Soviet Secret Projects - Bombers since 1945" and the Tu-144 (Soviet Concorde) was deeply analysed in Bomber version (on the drawing board and with industrial scale models); probably the same happened for the Concorde, at least a little, unofficially - or secretly :ph34r:
elmayerle
If anyone is interested, the article in the last issue of APR on Boeing's WS-110A (B-70) proposals includes a few drawings that give enough data on that aircraft's weapons bay that it could be used in developing one for the Bombcorde.
--Jane Wagner and Lily Tomlin
Archibald
Euh yes double planes have double fuel and rnginres but alos double drag. But your calculations are not bad, too. Thanks for the precision elmayerle I'd like to see that...
Shasper
Great, now I'm off to find a Tu-144 kit ^_^
Shas B)
- Bud S.
What a large whiff. Somebody over at the airfix forums are also doing a whiff like this using the heller kit.
Archibald
Well it's nice to see so many people making a concorde bomber. Sadly, it's thirty years too late... otherwise we could have try to make a concorde-bomber lobby, to push our governement to make it (in real). :P ....
noxioux
Is it just me, or is this project idea screaming for an internal bay scheme a la B-1B, with three modular bays that could accept a variety of pallets or rotary launcher?
Shasper
If they'll fit (reason why I didnt go that route w/t Mk.1), unless you do major redo on the fuselodge to accomodate the bays and the SRLs, much less the ordnance on them.
Shas B)
- Bud S.
Martin H
That rotadyne was built by Eddie Kruk, who finaly gave in to mine and Geoff P's nagging and joined the What if sig back in january at the Bolton show.
No idea who did that concorde thou.
I always hope for the best.
Unfortunately,
Size (of the stash) matters.
Archibald
It seem logical to have abomb bay on a bomber no? (salvo in the Mirage IV and Vigilante :P ). It was not too difficult to make (cutting the plastic in the right place with a metal scissor, then sanding a lot...)
waynos
#28
Love the concorde bomber! It looks fabulous.
Your whiff has reminded me of my first major whiff, 25 years ago! It too was a bomber based on Concorde but I took a different route, sadly the model is long dead but I wonder if I might recreate it?
I called it the BAe Anvil B.2 (it seemed a cool name at the time)
here are the changes I made, briefly. (Airfix, 1/144)
Fuselage - removed fin/rudder, covered hole with half a long thin fuel tank (1/72 Mirage III?)'ECM fairing'.
wing ; cut off tips, fitted swept back outer half of wing from 1/72 Jaguar to give new shape. Wing/body blending sculpted with filler, similar style to Mirage 4000 but slightly more exaggerated.
fitted twin fins (can't remember what from but similar shape to X-29 fin)) directly above engine centreline on trailing edge of wing.
canards (1/72 Hawk tailplanes) fitted above and behind cockpit area
colour scheme; the then current all over wrap around green & grey camouflage and B type roundels as seen on Vulcans at the time.
It looked bloody marvellous!  :D
:wub: Wonderful, it seems, yes, a twin-fin Concorde ^_^
Even if the actual model is dead, have you saved at least one picture? :huh:
